Can 35's fit!?!?
When I had my 02 I put 315 BFG A/T's and they rubbed pretty bad, yes I had to do some trimming. And that's not but a 34.5" tire and I was leveled...not a true 35. If you want to get aftermarket wheels I would try and stick with the same offset and BS has your factory wheels or has close has you can get.
And NO the more negative offset you get the more there going to rub.
