2012 Tire question
2012 Tire question
I'm new and about the pull the trigger on a FX4 SuperCrew. It comes with the stock 18inch wheels. I want to order the XD Monsters 20x9 with Nitto Terra 275/55-20. I don't plan to level it as of right now. Wheel that tire/wheel combo fit without any issues? 2nd, will the Factory TPMS sensors fit fine?
Thanks,
Lizard
Thanks,
Lizard
Yes, those tires and wheels will fit fine, and you could actually go a little bit bigger on the tires. I have 275/60/20s on my stock 4x4 and the fit good with no rubbing, and you can fit either size tire with 35 or 18mm offset. I think you can have the stock TPMS sensors swapped to the new wheels, but I'm not positive about that.
Since you have an FX4 I assume you have fender flares, so yes +35 will stick out a little farther that stock, but not past the fender flares. I have wheels with +32 offset and they sit flush with the fender flares in the front and rear. +18 will stick out about 1" from the flares, so either will work, just choose whatever you think will look the best.
