295/70-18 Trail Grapplers on -12mm offset wheels
how wide is the wheel...ive got some pics on two of my trucks of a wheel with a -12 offset.one is leveled and the other is lifted. both with a 12.50 wide tire and 9 inch wide wheel.
Those tires are about an inch narrower then mine, but you will get the idea when you see my pics in my gallery.
I would be more worried about rubbing than if they stick out too far. Without trimming they will rub pretty bad with that offset. A positive offset will allow largest tire fitment. Similar to stock specs will allow largest tire fitment if u only have a level. Do up have a lift on it?
https://www.f150online.com/forums/me...+-++truck.html
This has been an ongoing debate with some people on this site. ive owned a 05 and 06 both leveled with different wheel combos. I prefer a wider stance, but if you check my gallery the black 05 is 2.5" leveling kit with 35s and i did zero trimming with the cooper stt tires that i used. The offset was really close to stock though, thats why i was able to achieve this. the 2006 had a 3" level and the same specs as your wheel you are looking at. I had to trim the front valance and i sometimes rubbed on the fender flares, but they were packed with dirt and small pebbles and it pushed them out a little in the inner fender well. I ran 33s with that setup. So if you dont mind trimming to make them fit you will be ok, but if it were me id either change to the positive offset or keep the -12 and drop a tire size.
