New Shoes Time!!! Help me deicide
08 FX4 F150 Scab. Current tires Toyo AT 285 65 18 on stock rims. I want to go a bit taller to fill up the wheel well with no rubbing whatsoever. I am keeping the stock rims. Got a 2" autospring and 3" block. Also drive on gravel everyday. Here is what I have narrowed it down to but not opposed to another option. Help me decide.
Toyo AT 275 70 18
Goodyear Duratrac 295 65 18 or 275 70 18 Heard these were soft???
Nitto 295 70 18
Toyo AT 275 70 18
Nitto 295 70 18
Just so I am clear. The Nitto Terra's 295 70 18 will fit with no trimming and no rubbing? Pulling the trigger soon. Thanks for your help.
According to Nitto's site, your size is a little taller and little narrower so you should be just fine.
Toyo makes Nitto tires so the AT tread pattern is pretty close. Ought to look good once you get them mounted. Have fun over there on the Island!
So here's an update. I like the size of the Nitto but I like a tire with white letters and they do not offer that. My other option is the same tire that I have just a bigger size which is the Toyo AT. The 285 75 18 is what I have my eye on but just putting a tape measure on my current tires and the difference in size....It looks like they might rub on the front valance. I wish they offered something closer to 34" instead of almost 35". Maybe I should just get a 275 70 18 that will be a little taller than what I have and for sure not rub. Please guide me in the right direction.
You mean too wide? I think that height would be ok but the width on a stock rim might me a bit much. Definitely don't wide much wider than what I have due to the gravel roads and slinging rocks.
