new rims for my supercrew
i have a 2011 f150 supercrew and was planning on getting rims in the future. i found the ones i want, fuel gauges d504 (black w/ machined front). im not sure if i should get the 18's or 20's. also what tires i should get? and how much they would cost? its a 2wd so what are the biggest tires i could fit on 18's or 20's. if i were to level it im assuming i could fit 33's? correct me if im wrong. is that 33's on 18's and 20's? i understand backspacing a little bit but im not completly sure about it. thanks i really appreciate it
What kind of look are you going for? Do you want them to stick out more than stock or tuck in similar to stock? A positive offset will tuck them in more and allow largest tire fitment. If you keep the wheel specs close to stock you will be able to fit around 33s(295/65/18) with minimal if any trimming. Do you want a mud tire for looks or a more practical all terrain? Give more details of what you want end result to be and we will try and help you out.
I want them to Stick out a tad bit (like an inch or so) and ya a practical tire. I was wondering if I could find some 17inch rims I like and put my tires I have now on there, since they got quite a few miles left in them. I'm not sure if they stock 17" rim is the same as a aftermarket 17" rim. I'm new to all of this so thanks for the help
