Are 315/75R16 the tallest tire I can get?
Which size did you want to run? A 35x12.50 would be a little bigger and still fill out nicely compared to a 315/75/16.
Are you going to run an a/t again? Because they'll always look smaller than a m/t in the same size. But don't forgetti check the tire manufactures website too since all tires measure out differently than what's on there sidewall.
Not sure of the top of head what comes in a 35x12.50x16 off the top of my head. Nor in the 325/75/16. Easiest way to find out is type that size into to google and see which tires come up. The toyo m/t's are great tires though. And don't forget the tires will look a little bigger than what you currently have because of the tread pattern, and the 10" wide wheels.
