Rubbing with 35's
Rubbing with 35's
I am wondering what can be done with my current problem. I have an 09 fx4 which i purchased from a dealer who put a leveling kit which i was told is a 2.5 or possibly 3 inch and 35 inch tires. there was rubbing but not enough to make it a deal breaker. It is currently only rubbing on the plastic mud flap which i can easily cut out and fix however i am looking at getting some xd rims for the truck this spring/summer and have been told by a few that the rim will push out the tire further and cause more rubbing than there already is. Any thoughts?
I am thinking this is probably what I will have to do now that I have researched it a bit more. I could always just get smaller tires and go with aftermarket rims too. What is the recommended tire size for a 2.5 (or 3inch) level that would leave me enough room for a few options for wheels and minimal to no rubbing?
Had my wheel & tire setup on two different trucks. One 2" leveled, and my current one un-leveled. Very little rubbing on the 2" level on the lower control arms when reversing at full lock. Oddly, barely any rub on control arm or sway bar un-leveled. Perhaps the side lugs wore down a bit more however as I put about 25,000 miles on the leveled truck with these tires.
20x9 XD wheels +18 offser 5.71" backspace, 33x12.50/R20 Toyo M/T.
I would say, a 34" size tire would look best leveled as long as it clears. I am going with 295/60-R20s next.
2" leveled.
Same setup, un-leveled.
2" leveled.
