How do I know if I need new brakes?
Squeeking means that they may need replacing, but a visual inspection is the only way to know for sure. Its not very hard, all you need to do is jack the truck up, take the wheel off, and look at the brake pads. Look up some videos on youtube so you have an idea of what you are looking for. How many miles are on the truck? You may also need rotors depending on their condition.
If the rotors need replacing too is that something I can do as well? Brake pads seem easy from some videos I've watched. I know rotors would at least jack the price up. *crosses fingers*
I was thinking about going ahead and ordering these... http://www.autoanything.com/brakes/6...omerReviewsTab
Any input on those?
Any input on those?
I use Wagner ThermoQuiets and love them, but the Hawks are also good pads. If the rotors do need replacing then you shouldn't have a problem changing them. At 105k, the brake pads have probably been replaced once already, and if not they will most likely need changing. Rotors may/may not need replacing, depends on if they are warped or have bad grooves in them.
