accident waiting to happen...
I know there are tons of threads on this but my 97 has the classic mushy spongy brake pedal. mc was replaced 2 years ago, rear brakes were just adjusted and in perfect working order last weekend along with new front pads rotors calipers and hoses. bled the brakes the old school way over and over and there is absolutely no air coming out of any bleeder. also replaces mc cap gasket. brake pedal goes past the gas pedal before the brakes start to work. basically wondering if adjusting the booster push rod works and if bleeding the abs module is necessary
on
1 Post
Have you replaced your rubber flex lines?
They are a known issue with these trucks.
*Edited: Sorry I see now you did the front hoses. I would do the back too.
It is possible to get air in the ABS system but it is pretty rare but worth ruling out. It would need to be done by the dealer or a shop of equal caliber as sam1947 mentions below.
