I want to stay with taller tires. but...
My 07 2wd F150 came with P235 70 R17. I switched to P265 70 R17. I am in need for more tires soon. I would like to get an LT tire, but I want to down size the width aspect and keep in the 31.5" height range. Can this be done? So I would like something tall (+30") but less than (10") wide, or at. This would be for less rolling resistance... (gas mileage). Would a LT245 70 R17 work safely on this truck? Yes, No, and if no why not?
Thanks for the replys. Since my truck is 2wd it sits lower than a 4wd. I like the profile of 31"+ taller tires, but I don't want the wide width (11"). I was just doing some reading about rolling resistance vs gas mileage etc.. So I was just curious if the 245/75 would work. Less resistance plus the height I was looking for. I also found out that I have the 3.55 rear gear, and looking into 3.73 to compensate the tires plus better towing. I'm not interested in 4.10 or lower gears, I just cant see running that low for my regular driving. Keep the questions and suggestions coming, please and thank you.
This is true. But I'm not trying to increase mpg. Just trying not to lose any extra! Thats why I mentioned taller with narrow tread vs 11.5 inches wide on a 32". The 3.73 rear gear is just because I haul and tow on a regular basis--- ford 661 tractor on a 3k lb trailer. Or bed full of wood, equipment. etc... I also drive rural roads (hills,curves,slow drivers!) so I feel the lower gear is more needed for longevity of trany, and to tow better. I just was wondering if any one else has used a narrow tire on these trucks, and did they like it or hate it.
