need tpms help
In more than one case, it has been found that the best thing you can do is purchase a reset tool. The newer procedure (let air out) does not always work. You can get the dealer to do the reset, but basically what he will do is use a reset tool.
http://www.ebay.com/sch/6000/i.html?...vxp=mtr&_rdc=2
Edit - If you get the tool, you can follow the procedure to reset the sensors at the following site. Just download the 2009 owners manual. That year did not use the lower air pressure method. It required a reset tool.
http://www.motorcraftservice.com/vdi...&menuIndex1=13
