2011 f150 biigest tires???
RIght. Also a 12.50 inch wide (305mm/315mm) Toyo MT is probably gonna rub the upper ball joint/control arm using the OEM 20 inch wheels. The problem is the OEM 20x8.5's have 6.5 inches of backspacing which pulls the tire inward. The clearance is so tight that some 12.50 inch wide tires will touch and some won't. Specifically it's usually the Toyo MT's and similar mud tires with aggressive sidewalls.
