Need brakes. Recommendations?
i hear ya. totally your call, totally your truck. if someone else chimes in and says otherwise ill listen, but in my experience i always stick with OEM rotors. you can totally try a different rotor. i just wanted to give you my 2 cents haha! goodluck though and let us know how it works out!
Both of my OEM rotors on both '04/'07 trucks were chewed to an inpleasant death via seized caliper. OEM rotors are decent disks, but I will bluntly say our OEM calipers suck, however the genius in me replaced them with brand new motorcraft still ![lol](https://www.f150online.com/forums/images/smilies/lol.gif)
My setup, Powerslot ( now name branded as StopTech ) slotted rotors, not drilled, Hawk LTS ( light-truck-suv ) semi-metallic grade pads with fresh Motorcraft Dot 3. Stops excellent. Also replaced the brake flex lines with new motorcraft cause I had to get it on the road asap, otherwise I would have done stainless braided.
As it is, it stops great. Did it all myself, $600 invested, free labor aside of refreshments.
I do not have any photos but I can tell you that the pads look almost new, still thick and wearing great. Next time I have the wheels off I will try and take a photo. I am very pleased with how great they look inside the calipers and the rotors themselves aren't grooved nor have any wear spots. You get what you pay for as they say.
I will do some digging tonight when I get home from work. I am not 100% certain, but I think I have a set of EBC Greenstuff 6000 front pads in a box of spares in my garage. If so I think I am going to...
#1. Get the matching set for the rear. If they aren't there, I will go ahead and snag front / rear sets of Wagner TQs.
#2. While I appreciate the experience of folks here. I have been asking some friends in the business, and they are using the Raybestos rotors as they get the least call backs on them. From what the pros I am talking to are seeing, the Motocraft rotors are prone to warping, and that is what I experienced with mine.
#3. Grab a fresh tube of silicone brake lube for the slides. I have not experienced what DarrenWS6 has with the calipers, but then again, I do not live in the rust belt either. I simply clean and lube the mating / sliding surfaces before reassembly.
I had issues with my Raybestos... I'd rethink that man. They have a terrible rep from what I googled for our trucks.
I ordered off Amazon the Centric conversion kit (I'm 2wd), and new centric front flex lines... 297 shipped. It should be here tomorrow. I have a spare set of Semi metallic pads I'll be putting on.
