Tire size
Pull off the wheel and check to see if the size is stamped on the inside, normally it is. Otherwise at least post the model of the wheel if you know or a picture of it so we can narrow it down some.
Otherwise anything we guess at could be completely wrong and you could end up with a set of tires that are too big and won't fit properly.
