2013 after market wheel question
I looking to change the tires and wheel on my 2013 lariat 4x4 offroad. i was looking to put a 17x12 rim with a tire as close as i can get to a 33x12.5. The rim I am looking at is a weld T58. it has a back spacing of 4.8 with -19mm off set. The tires i was wanting are mickey Thompson claws size of 305/65r17. Does anyone know if these will fit stock or will i need a lift/level in order to turn with minor to no scrubing? I really want to keep the truck as low as possible
With a 12 inch wide wheel, I'd go with a 6 inch lift. Also, a 305mm (12.50 inch) wide tire is too narrow for a 12 inch wide wheel. I'd go with at least a 13.50 inch wide tire. Your fitment problems are gonna be caused by the wheel. The one you want will stick out almost 5.5 inches farther than the stock wheels.
Most 305's are right under 12.5" wide. Some people do it, but it doesn't look right imo, can cause abnormal tread wear, can blow a bead a lot easier, you basically leave the rim no sidewall protection from curbs, some shops won't even mount them, etc. There's plenty of people who do it, you see it alot with the ricer crowd and the cali trucks, but there's also plenty of reasons not to do it.
You usually wanna go at least an inch wider tire than the wheel. So a 13.50" tire would be perfect on a 12" wide wheel.
