Impending Wheel Purchase...
2002 F-150 S'Crew Lariat FX-4
So, I'm getting ready to by some new wheels. Here are the specs...
Offset: -12mm
Backspacing: 4.49"
Weight: 30.45#
Construction: 1pc Gravity Cast
My question is this...what are the largest tires I can "safely" mount on the aforementioned wheels? Thanx.
Offset: -12mm
Backspacing: 4.49"
Weight: 30.45#
Yes, I know, it is a somewhat odd question. I am wanting to get a bit of a rugged look without the lift...and at the same time, not have to worry about a bead breaking when I go off road. Thanx.
I had my current wheels and tires, 305/70 16 on 16X10's for years before I got a lift; so yea, they'll not only fit, they'll work just fine.
Again...anything that will fit on your truck and (arguably) any off roading you'll be doing in a pretty much bone stock truck is not very likely to bust a bead.
I had my current wheels and tires, 305/70 16 on 16X10's for years before I got a lift; so yea, they'll not only fit, they'll work just fine. Again...anything that will fit on your truck and (arguably) any off roading you'll be doing in a pretty much bone stock truck is not very likely to bust a bead.
So, I have one last question for y'all. I will obviously need a different way to mount my new spare tire, so right off the bat, I'm thinking bed-mounted. However, I'd like to find one that doesn't require drilling the bed...you know, to be able to use the existing bed bolts somehow, but I've not been able to find one. Here's what the spare tire holder needs to fit...
