ABS Module Replacement
![Question](https://www.f150online.com/forums/images/icons/icon5.gif)
Hi Guys,
Hopefuly I have posted this question in the right area of the forum.
Anyhow my truck is the 2002 F150 Harley Davidson 5.4L V8 Supercharged version and it needs a new ABS module. Unfortunately the previous owner didnt remove it properly and basically rendered it useless and unable to be repaired.
Therefore my question is, will any ABS module from a standard F150 from around that time be a suitable replacement?
Appreciate any help.
Cheers
Cheers
The only difference I could think of is if potentially they put a different set of parameters on the HD version due to larger wheels.
But typically they try to use the same module on all versions.
Maybe try going to a parts website and plug in your vehicle info and see what PN they list for the module. Then change it to a different vehicle (XLT, etc) and see if the PN changes
