33x12.5R15???
Whats the smallest rim I can go with? I like the smaller rims and bigger tires look.
http://www.summitracing.com/parts/mtt-1160401/overview/
http://www.summitracing.com/parts/bfg-92042/overview/
The tires will fit fine, the wheels you linked however won't fit your truck. The linked ones say the bolt pattern is 5x5.50, your bolt pattern is 5x135mm. 4.5" of backspacing is a good choice though.
Here's a link to those same wheels, but with the right bolt pattern:
https://www.ntwonline.com/16X10-5X13...ek-Wheels.html
Also a 305/70r16 would fit a little bit better on the wheel and help it fill out the wheel wells a little more. It's about the same height and about .7" wider. And the BFG A/t is available in that size.
