Factory Tire Pressures
After reading the article about tires being underinflated, I decided to check the pressures on mine even though it went through shop prep and delivery to me now only 14 days ago.
To my horror, the same thing has occurred again that happened to us last year when we took delivery of our first F-150 SCab.
When I checked the tire pressures, the right front was at 39.5 psi cold and the left front at 42.5 psi cold. The left rear was at 38.5 psi cold and the right rear at 37.5 psi cold. On our SCab last year after we took delivery from the same dealership the pressures all the way around were almost a uniform 45 psi.
Now what I don't understand is don't these morons read at these service departments and maybe factories too? I mean it says right on the side of the Goodyear Wrangler that maximum pressure is 35 psi cold.
I'm going to call the salesman we have worked with the last year on both of these truck deals and find out why its delivered with tires grossly overinflated.(front is supposed to be 30 psi and rear 35 psi) Maybe this is the reason so many of those Firestones blew out. Not just underinflation, but overinflation by these dim bulbs.
Anyone else ever check there tire pressures soon after taking delivery and have the same experience?
I doubt ANY service dept. checks tire press. (although they should) - you are best to get a gauge and check your own, with the same gauge, when tires are cold.
The tag on the drivers side post should tell you recommended pressure.
You can increase this if you want, slightly, but - NEVER excede the pressure ratings on the sidewall of the tire.
Never run lower pressures - this causes heat & failure.
rr
rr
Re: Factory Tire Pressures
rr
rr
I run 35 in all tires, despite the door jam tells me 29 front 32 rear. When the pressure is that low the ride is considerably sloppier and the tires skid around every corner. Like what was said earlier, don't go over the max tire pressure or you will blow a tire like the guy who did my oil change. He got side tracked and left the nozzle on too long while i went to pay. We slapped on the spare and it was quite embarrasing for the guy. This happened a few months ago.
Travis
Travis
On all my "P" (passenger) tires, all vehicals, I run 35psi cold. I like the road feel, handling, and I'm getting good wear. They are checked at least once a month, every two weeks in the winter. During winter I see a 1psi change for every 10 F temperature change.
When I up grade to LT tires, C load rated, 50psi max, I'll run 40psi when running empty, and 50 psi when loaded down.
