315 or 295
Old 08-16-2015 | 11:22 AM
alex06's Avatar
315 or 295
06 4x4 rancho quick lift level
Rims are American eagle 17x8 5.19 bs
Really wanting 315/70/17 but worried my rub or cause
Issues so my brain is trying to talk me into 295
Help me with thoughts
Old 08-16-2015 | 12:57 PM
I have 295/60-20 Nitto Trail Grapplers with 20x9 XD wheels +18 offset. When I had mud guards on they rubbed, but otherwise they didn't touch anything. I have since added Bora spacers, and measure my offset to be about -18 now. Looks great, rubs the lower corners against the cab pretty bad though. So I would stick with the 295 on a non suspension lifted truck.
Old 08-16-2015 | 04:18 PM
alex06's Avatar
I think my offset is 20 and lift is 2.5 from ranchos not planning on spacers
Old 08-16-2015 | 06:29 PM
pizzaman711's Avatar
You'll most likely be doing some trimming with 315's and those wheels. 295's and any rubbing would be minimal if at all.
Old 08-16-2015 | 07:39 PM
alex06's Avatar
Like trimming the plastic under bumper?
Old 08-16-2015 | 07:51 PM
That, the inner fender liner, and you'll probably still be rubbing the frame when turning at full lock.
Old 08-16-2015 | 08:42 PM
alex06's Avatar
Would love to get 305/70/17 but can't find any good ones
Old 08-16-2015 | 08:46 PM
The specs on those are close to the ones I had my 315x70's on...I had 17x8 with 5.5 inches of backspacing and had no rubbing with the tires. Your's are only close to 1/4 inch difference and will only stick out about 3/4 inches more then stock. If you run all terrains like the BFG's you should be OK on a leveled 4x4.
Old 08-16-2015 | 08:50 PM
'04 Lariat 4x4 I had that was leveled 2-1/2 inches...315x70x17 BFG TA/KO's on 17x8 wheels with 5.5 inches of backspacing....no rubbing.
Taken at Grand Isle, La.
Old 08-16-2015 | 10:12 PM
alex06's Avatar
What about MT wanting deegan by Mickey Thompson the specs say 34.4 diameter
Nice truck as well
Old 08-16-2015 | 10:15 PM
alex06's Avatar
The Kos show 34.5 diameter should be close to same
Old 08-16-2015 | 11:18 PM
What you have to watch are the side lugs on the MT tires...the 315x70 is close to a 35x12.5x17 and the side lugs may cause rubbing on the upper control arm which you can't trim. Better chance of clearing an all terrain tire. I also ran some 295x70x17 Toyo MT's (33.5x12x17) and those cleared with no problems...even when I had them on 17x9 wheels.
Old 08-17-2015 | 11:30 AM
alex06's Avatar
I guess if the side lugs rub some I could run a small spacer.
Old 08-17-2015 | 01:28 PM
That may help if they rub on the inside.
Old 08-17-2015 | 11:46 PM
Babylift150's Avatar
http://tire-size-conversion.com
Amazing website will tell you sizes down to a tee..
