Having Problem replacing front brake pads on Expedition
I tried today and did the rear brakes without a problem, but when I got to the front I got stuck. The front has 2 T45 bolts holding the calipers on in some sort of craddle. Once I take the 2 bolts out, I can't seem to figure out how to get the calipers out of the caddle the caliper is housed in. My Expediton is a 98 2wd. Thanks in advance,
JMan
JMan
This thing has 2 calipers on each wheel, I have looked at this thing a hundred times and I can't see how to get the calipers out of the housing it is in. The pads themself have notches in them that fit into this housing. There are some clips that the notches in the pads fit into, but don't want to bend the clips to remove the pads. This is a tough one for me. I have replaced many brakes, but can't seem to figure this one out. I guess I'll go get the haynes book.
Thanks,
JMan
Thanks,
JMan
Tubaman,
Mine also is a dual piston, so we must have the same. Once I remove the bolts, which way do you pull to get the caliper out. When you say caliper is that all that should come out, or are the pads attached to the caliper as they are in the rear, if you you can understand what I mean. Also are the bolts that you have to remove T45 bolts?
Thanks,
JMan
Thanks,
JMan
Thanks Tubaman,
I got it figured out and have completed the changing of the brake pads. I was not compressing the pistons enough and the caliper was stuck to the brake pad. Once the piston was compressed enought the caliper let go and I was able to complete the changing of the pads. Thanks again,
JMan
JMan
