305's or 285's
305's or 285's
Im looking to get new tires but im not sure which size to get the 285x75 16 or the 305x70 16, I know these are both about the same diameter? Does one ride better than the other? I have a 2 wheel drive with the fabtech 3.5" spindle lift in the front and 1.5" blocks in the rear and running the stock 16" rims. Thats the other thing will I have a problem mounting either one of these tires on those rims? Any help would be appreciated.
I AM RUNNING 285/75/16 ON FACTORY RIMS AND COULD NOT BE HAPPIER. But when I went in and had the 305/75/16 mounted, it looked a little ballooned out. Just kind of strange looking....
And here is the conversion for those 2 tires.....
285/75/16 = 32.8" tire
305/75/16 = 34.1" tire
I would go with a nice 8.5- 10 " rim....
That is just my opinion.......
p.s. StevensBlack4x4 that is a sweet lookin truck !!!!
Well first check your tires sizes here people. He's asking about a 305/70/16 not a 305/75/16. A 305/70/16 is the same height as a 285/75/16. Its just wider. Its not the same as a 305/75/16. But neither of the 305s will fit on stock rims safely. You will have people say "Well I have been doing this for a long time and I haven't had any problems." but it doesn't mean its safe. I'm not sure about fitment on a 2wd with that much lift.
Thanks for all the input. I looked on the Fabtech web site and they claim with that lift I can go up to a 295/75-16. So I think I will be okay as far as clearance goes. I guess I will go for the 285's at least there wont be as much drag with the slightly narrower tire and I can keep my stock rims for the moment. One question, how do I correct the spedo issue on a 2001? Also will the truck be a dog with the bigger tires? How about towing?
