Tire size
Old 09-13-2021 | 05:24 PM
VMAC84623's Avatar
Thumbs up Tire size
I have a 2016 XLT with the H.D Payload package and I need new tires. I want to go larger and fill the wheel wells out a little without putting a leveling kit or suspension lift on it. Can someone tell me the largest tires i can run? What brand would you recommend also? Ford dose not recommend any size other then factory sizes. 275/65/18. Any help would be greatly appreciated.
Old 09-13-2021 | 07:39 PM
2wd or 4wd? Standard, extended, or crew cab?
Old 09-13-2021 | 08:10 PM
VMAC84623's Avatar
4 x 4 extended cab
Old 09-23-2021 | 01:17 PM
VMAC84623's Avatar
sorry i posted to my post not reply to you. I have a 2016 f150 xlt extended cab 4x4 with the hd payload package. I don't want to level it but want bigger tires. I cant find anyone that know a good size without cutting or leveling the truck at all. any elp would be greatly appreciated.
Old 09-23-2021 | 02:26 PM
Do you want to keep the original wheels? If so, not much choice.
If you want to get 20's:
I do not know about fit, this is just what Discount Tire shows as available. If you have 7 lug wheels, I don't know if you will find any 20's.
Old 09-23-2021 | 03:07 PM
VMAC84623's Avatar
thank you. Inwas trying to keep factory wheels. If I can't then I will just level and change the rims. Thank you for your responce.
