Which fims fit?????
I guess it's just my personal preference. I like the looks of the ORP rims and have planned on getting them since I purchased my truck. As for tires, the set of goodyears i'm planning on getting are 15 bucks cheaper per tire for the 17's. I don't really buy tires all that often, as they usually last for about two years on my trucks, so tire choices aren't much of a factor.
'97. '98, and '99 (I think) have 12mm studs, '00, '01, and '02's have 14mm studs. You can use the new rims with 14mm lug holes on the 97-99 without a problem. You can't use the 07-99 rims on 00's and up because the lug holes will be too small. There are quite a few folks with older trucks riding on the new rims without any problems. Good luck!
