Brake Problem
Brake Problem
I've got an odd brake problem. Recently I've had to apply more pressure to the brake pedal to stop than I used to. A few times my ABS has come on when I had to make a slightly quicker stop. I just put new pads on the front (about 3000 miles ago) and I initially had no problems.
I've checked the brakes and the master cylinder and everything appears fine. Any suggestions?
I do have a CB hardwired into the truck's electrical system, but I only use the antenna when I go on long trips (it's a magnetic-mount). I installed it not long after I bought the truck in '98, and the brake problem has just emerged recently.
I'm curious if anyone else has had similar problems to mine after installing new front pads.
Sounds like you might have knocked one loose or one of the wires is shorting out. Did you open the bleeder screw when you pushed the caliper piston back? I have heard ABS sensor can be damaged besides ruining a caliper. If you can't get it fixed I reccommend taken it to a dealer or qualified brake shop because in my opinion brakes is something that is diffently needed.
Matt90GT,
Did not turn the rotors when I did the brakes, but they appeared fine. I only have rear ABS, and the sensors are fairly clean.
KYFordFreak,
I made sure to open the bleeder when I messed with the brakes. I wasn't aware to the the potential damage to the ABS if this isn't done, but I sure didn't want to ruin any of the other components.
The ABS has only acted up a few times, I'm a little more concerned about the increase in pedal pressure to brake. Anyway, I just received a coupon in the mail for a free brake inspection at Midas, so I think I'll take the truck to them to see if they can shed any light on the problem. I'll let ya'll know what the diagnosis is.
KYFordFreak,
