Spare Tire Damage!!!
I just pulled down my spare for the first time and found marks where the frame had rubbed against the sidewall of the tire, ruining the sidewall!! Has anyone else experienced this? I've replaced the tire, but I'm not sure how to protect it from the same fate. Is there a cover or separator that should be there? Any Ideas? Thx for your help.
director,
I read about this, here I think, jsut before I got my truck. I got a flat tire 180 miles into ownership, when I fixed the spare I cut a piece of carpet to put between the tire and truck. Although it is getting ratty it does work, I am looking into replacing it with a sheet of teflon.
Ed
Ed
on
Only everybody...
I was going to say do a search but, when I did over six pages came up with hundreds of posts.
Put something between the tire and frame.
Some use carpet.
Cardboard don't work, just ask... me.
A piece of pywood would work but, tricky to cut and it might rattle.
An old inner tube (deflated).
Who did come up with the best idea?
Some use carpet.
i am using my once spare as my fourth tire and the one that had a 6' gash in teh tread from some A** that cant throw razors away insead throws them out the window. sorry just had to let a little steam. well on with the tire it had only a few marks on it so i just cleaned it up good. sounds like i got lucky. now this thred has reminded me that the flat tire is there and i need to get a new one before i need a good one
on
Little over a year ago I had to use my spare and it had the rub marks on it but there didn't apear to be any other dameage to the tire. I put around 2000 miles on the spare before putting it back in it place as I was on vacation. I had to buy a new rim and tire as as I damaged my rim and tire during the blowout and waited til I got home to get the new rim and tire before putting the spare back.
Thanks all for the ideas - it seems stupid that there wasn't some form of protection like rubber bump pads or something! - I'm going to try some chloroplast, the stuff plastic signs are made of, to see if it will protect the spare. Maybe I should have mentioned that I have the 17" rims, it might make a difference. Thanks again!
spare tire damage
After dumping the goodyear rt/s for BFG Rugged Trails, I went back to the shop for them to change my spare. When they took it off it had six depression/rub marks on it. The guy at the shop said it would be ok to use. I dont want to buy a brand new tire and have it rubbed like that. I really need to know if the carpet does the trick because I went from 255 to 265 and I would really rather have the same size spare.
I would appreciate your thoughts and opinions.
