Rotating Tires.
on
I have 12000 miles on my SuperCrew; rotated the wheels at 5000 mile intervals and show very little wear. The original Goodyear RT/S tires are terrible at 70 mph and higher or when it's windy. I think I'll let them go and replace them with real tires this summer! Rotating does work though.
Free tire rotation
Discount Tire, a national chain, rotates tires and does flat repairs for free. No gimmicks, does'nt matter where your tires came from. When you can get it done free with no hassle it makes sense to rotate frequently(5000 miles) as recommended.
I don't work for them just happened to stumble across the deal when I had a flat.
I rotate my tires when I start noticing significant wear on the fronts, usually around 20,000 miles. You might think that's way too long but I get well over 50,000 miles per set. The less times you take a tire off the truck the less likely the expensive alloy wheels are going to get damaged.
