Just a thought I have a 98 f150 4x4 lariat x-cab I went with 34/11.50/17 They fit great and no rub nor cutting required and the good thing is I have a friend with a 96 z71 with a 4" body and it sat 2" taller then his lifted truck
the only thought to my mind (oh what a feeling)
I have a 98 ext cab with 305-70-16's, no lift. The pro comps rubbed bad. I have since cranked the torison bars up half way and no problems now......hope this helps.
Hey mike how is the ride since cranking the torsion bars has the ride gotten stiffer I've also heard that adjusting them will change your alignment and can cause cupping or strange tire ware did you get an alignment after turning them up
