ABS Fix
I've read here in another thread that the sensor is bolted right to the rear axle. There should only be one sensor on the axle with a wire going to it. Probably held in my a bolt or two. Replacement is easy. Unbolt it, disconnect, connect new one, bolt it in I think.
I'm not sure if it's a magnetic, electronic or visual sensor. Probably visual so there may be a small lense to clean.
Haven't done it myself though. There is a special wheel in the ring gear where this sensor reads from.
Fixed it
Finally got to the dealership to get the part (sensor). Needless to say, the major auto parts joints didn't carry the animal. That surprises me due to the sheer number of these units that go bad. The local Ford parts man sez that Ford reccomends that they stock 21 of these sensors!!! At any rate, cheap 10 dollar fix, took less than five minutes to R & R (took longer to find the 3/8 socket). Thanks for the help, guys.
