Changing tire sizes to bigger tires?
My guess is it prolly has something to do with a 4x4 transfer case. Hi range / low range? I'm a 2WD driver so I can't say for sure.
When I entered my data for some typical winter tires for my Lightning, I got:
Old tire dia: 28.4
New tire dia: 30.0
Differential gearing: 3.73
New gear ratio: 3.53.
Which, according to my calculations, is correct (and just fine for winter driving). I just ignored the Hi/Low info. ymmv.
Anybody else?
Old tire dia: 28.4
New tire dia: 30.0
Anybody else?
Check out this site to find out everything you need to know about tire size changes....
http://www.c5-corvette.com/tirecalc.htm
This is a good tire calculator for figuring the speedometer error and it can also calculate the effective (rearend) gearing change and RPM difference.
Hope this will help others.
Here it is in "layman" terms.
The more the driveshaft spins per revolution of the tire, the more power you percieve having (at 20 miles per hour, you will be a 2000rpms, while with lower (higher numerically)gears you'd be at 2500rpms. More power, and towing earlier. Factory Ford basically shows a 400 lb +/- for every jump in gearing.
Every time you raise or lower your tires by 1 inch, you should feel a subtle change in performance. A few inches will be significant, and power loss especially noticed on the highway, where altered aeordynamics come into play. I would just guestimate that 1 inch +/- = .30 of gearing loss or gain.
Realize that tire and rim weight also make a significant difference in vehicle handling. Going one or two plus sizes taller on a rim/ tire could add a few extra pounds per wheel-which may not seem like much-till you consider rotational mass (1-2 lbs heavier per r/t combo can be significant). This will negatively effect ride, handling, braking-though can increase traction and looks.
Compared to my old 97 (17's w/3.73), my old 2000 (17's w/3.55) and now my 98 with (16's and 3.73's) it feels like I have 4.11's!! At 75 mph I'm at nearly 2400 rpm's. I am looking to lower that number to around a 3.70, and will do so by adding an inch taller tire (and an inch wider).
Anyone want to buy some 6 month old 255/70 16 BFG all seasons...?
