Brake rotor replacement on 2wd 97 F150
I attempted to do this today, but got stuck at the rotor removal..... I read the HOW TO ARTICLE about the front brake repair, but my situation seems way different. The rotor seems to be pressed on or some crap. Maybe its because mine is a 2wd and not a 4wd model? Who knows....id like help!
I went ahead and put my new brake pads on, seeing that the OE rotors seems OK, but just for future reference, id like to know this answer to this!?!!!?
Thanks,
Tony
Thanks,
Tony
Originally posted by LE PEW
Did you remove the grease cup, cotter pin, nut retainer, nut, and outer wheel bearing first?
How doi get all that stuff off, i didnt notice any hardware around that area? Do i just hit the grease cup and it comes off? Walk me through that, if you dont mind?
Tony
Just replaced my rotors and pads on 97 F150XLT 2WD. Pull off the grease cap (I used a slotted screwdriver and tapped it into the spot where the base of the grease cap meets the rotor surface). Once the cap is off, remove the cotter pin, then the nut will come off. The simply pull on the rotor, and it should pop off. and the outer wheel bearing will come out also. Once the rotor is off the spindle, the inside wheel bearing can be removed by first prying out the grease seal that holds it in. I would repack the bearings for sure, and use a new grease seal. When you reinstall, be sure not to tighten the nut too much. The manual I have says to use a torque wrench, and tighten to 30 ft/lbs as you slowly spin the rotor. Then back off about a 1/4 turn, and use the cotter pin to lock the nut in that position. Good luck!
