will lightning wheels fit?
Well, if the size of the L wheel didn't change since the 99 model which I highly doubt, they will fit. The only thing you'll want to do is relocate the brake bracket to the inside of the A-arm and replace the bolt with a pan-head screw which is narrower. If not, this bolt might scrape on the inside of the rim when you crank the wheel all the way. Do some searches and you'll mind more info.
josh
josh
