12 and 14mm stud question
12 to 14-
Hey, that works the other way too.
I had a 1999 F-150 S/C Flareside. I traded it in on a 2000 Expedition. Both were 4 x 2, both were 5 x 135mm, but the 2000 had a 14mm lug, and my A/R Atlas' were made to fit my 1999 S/C, which were 12mm.
The holes lined up perfectly, the guy told me my lug nuts wouldn't work, and I needed to go buy twenty 14mm RHT acorn lugs. One trip to discount tire, and 30 bucks later, the 14mm 2000 XLT Sport Expedition was mounted with the A/R Atlas wheels that I sported on my 12mm 1999 S/C Flareside. (My acorn lugs were the long chrome ones, not the short stubby ones... If that makes a difference. Purchased at Discount Tire.)
Different wheel manufacturers may turn out different end-results, but my AR Atlas' bolted up with no drama, and I went up in Lug size. You should be OK coming down from 14mm holes to 12mm lugs.
Expy-
Had- 295/65/16's mounted on A/R Atlas'
Have- 275/55/20's mounted on A/R Vanguard's...
Expy-
I've been wanting to switch to a different 17" stock rim, from a later model. How much effect does the larger lug size have on this change? My stock 16" wheels had lug holes that were quite a bit larger than the lugs. Is there any real danger in switching to a later model stock rim??,,,,,98
