33x12.50 tires
I know you can run a 285 series metric tire, which is about 1" narrower and approximately the same height without rub. These are good size tires IMO. The tire store swore they would rub, after pursuading them to try one because we knew better (we almost got them to give us the tires if they didnt) they fit with pleanty of clearance. Your first problem will be them rubbing the front fender on the passenger compartment side.
https://www.f150online.com/galleries...2380-31221.jpg
I don't know if you are running factory 17 inch rims or not, but if you are check out my gallery. I am running GY 305/70/17 MT/Rs on the stock 17 inch sawblades. I haven't had any problems and do not have any rubbing problems. I do not have a lift.
Hope it helps.
Hope it helps.
