99 Abs Discs
Old 04-11-1999 | 07:38 PM
Rexcars's Avatar
99 Abs Discs
Im just amazed. It's been raining of and on for the past 2 weeks and I've tried to lock up my 4 wheel abs discs on all the different surfaces I could find. The Truck stops straight as a arrow every time and not one chirp. My old Bronco would definitely be swaping ends. Anyway If your going to get a new Truck the abs system works unreal and with the new rear discs, Well lets say it's a great combo. Thanks Ford.
[code]Rex 99 F150 XLT S/C S/B 4.6, Auto, Solid Black, Dark Graphite. Santa Monica Ca.[/quote]
Old 04-14-1999 | 09:22 AM
manny's Avatar
Glad to hear that. The truck's braking capabilty had been criticized in the past. I have ordered a '99 F150 SC (should be here Friday) and was glad to learn that 4 wheel disk ABS were standard. Has anyone seen any road tests reviews (braking distance) for these new F-150s? Consumer Report only had tests for the 98 model (I'm not sure they had 4 wheel disks).
Old 04-19-1999 | 04:35 PM
f150luva
Guest
Posts: n/a
I have a 99' f-150 and my ABS light has came on twice, but went off overnight. And i had an Remote car Start/Alarm/Keyless Entry and it has been fixed 3 times already. Could the alarm be doing this? This is the first time I have ever had any problems with Ford. But the ABS works like you wouldnt believe!
[This message has been edited by f150luva (edited 04-19-99).]
Old 04-19-1999 | 04:51 PM
fin2lean's Avatar
f150luva
Is this an aftermarket unit? A couple of months ago somebody had some electrical problems with his 150 after they installed a remote start unit.
Paul
Old 04-19-1999 | 10:03 PM
ransome123's Avatar
When I bought my truck I refused to pay the outrageous price for their aftermarket alarm/keyless entry system. They removed it before delivery. Few months later I installed something or other and had taken the dash apart. I found they had left 15 feet of wire, several relays, and a fuse or two spliced into every wire imaginable under there. Took me hours to remove them all and patch the damage. I even had to add 6" of 6 or 8 ga. wire to correct one of their cuts on what appeared to be a very major power wire way up in the dash. It was an ugly, ugly day. Needless to say I am very careful in choosing the people I allow to wire, fix, or add anything to my truck. Some of the guys out there doing these things are butchers.
97 F-150 XLT S/C FlareSide 4x4 4.6L Auto 3.55LS Portofino Blue/Med Graphite, Gibson Cat-Back, K&N Element, AirBox Mods, FogLight Mod, SmittyBuilt Nerfs, Skid Plates, DuraLiner, 285/75/16 BFG's, AfterMarket AM/FM/CD, Amp, Speakers, Uniden CB, Wilson 1000 Antenna
Old 09-07-1999 | 09:38 PM
54regcab's Avatar
Thumbs up
I must agree the ABS/Rear disc combo Rules!!
99 XLT 5.4L reg cab
4x2 120" Wheelbase
4 wheel disc brakes/ABS
5 star larait style wheels
Toreador Red/Silver
3.55 gears 255/70/16 OWL
Delta toolbox
Eclipse 5340 cd player
Memphis ARCS50 component speakers w/tweeters mounted flush in the door panels (excellent sound)
Sherwood 35x2 RMS amp for components.
Jensen 50x2 RMS for subs.
2 6.5" Bazooka tubes
Lowering shackles?
